2000 head coolant passages...
Old Aug 30, 2012 | 12:31 PM
Externet's Avatar
Question 2000 head coolant passages...
Hi all.
From looking at pictures, the heads coolant intake is by its rear end, -about 3 inches x half inch ? behind chambers 7 or 8-
What is the size on the coolant passage exiting the head, and where is it located ?
Thanks
Old Aug 30, 2012 | 01:50 PM
Out thru the intake manifold and the hose port (#17 in attached drawing) is located at the front. Various models have other small ports for heaters, etc. The heads to manifold water pasages are the corners. See pix of valley pan gasket. They are known to leak because Bozo did not tighten the rear bolts, some have been reported finger tight.
Attached Thumbnails 2000 head coolant passages...-hg-rear-2.jpg   2000 head coolant passages...-d1-valley-pan-gasket.jpg
File Type: pdf
jeff.marsh
LR2
Feb 24, 2023 06:55 AM
Fonzibonzi
Feb 13, 2015 05:00 PM
dancedisco
Feb 6, 2012 06:34 AM
jcostello
Nov 2, 2006 10:28 PM
