2000 overheating
Old Mar 18, 2010 | 12:49 AM
bt-dub's Avatar
Default 2000 overheating
First I want to apologize for my re-posts earlier, im slow in learning the forums. Anyway, I am looking at a 2000 Disco with 65k on it. The guy is asking $5k. The problem with it is that it overheats. He said he replaced the thermostat and the head gasket and the problem continues. He also said a mechanic told him it was the radiator because it has a cold spot on it. Does this sound correct? Is there a way to check the radiator myself? He also told me it would cost around $500 to replace the radiator. Does this sound correct? Any info is great. Thanks everyone
Old Mar 18, 2010 | 02:23 PM
bt-dub's Avatar
Has anyone else come across this sort of radiator problem? Any help with the overheating issue would be great. The rig seems to be in great shape besides this problem. Thanks
Old Mar 18, 2010 | 02:38 PM
Frank4's Avatar
You probably have air in your coolant system and it needs to be bled properly, I believe there is a sticky for that at the top. I would get on it before you warp your heads or blow another gasket. Are you experiencing the "waterfall" sound coming from the glove box area?
Old Mar 18, 2010 | 02:42 PM
bt-dub's Avatar
It is not my rover. I am looking at it as a potential buy but im scared of the overheating issue. Basically im trying to figure out whether or not the rig is worth buying for $5k with 65k miles, its a 2000.
superdejison
Feb 1, 2010 05:13 PM
alphawolfman
Jul 24, 2009 03:25 PM
Kennyr996
Oct 13, 2008 10:19 PM
wadematt
Jun 12, 2008 09:30 AM
procurbusa
Aug 14, 2006 03:19 PM
