2001 DII brakes--anyone else experience this?
Old Aug 21, 2009 | 09:55 PM
Disrover's Avatar
8th Gear
Default 2001 DII brakes--anyone else experience this?
When I apply the brakes, the pedal goes about half way down ---if I pump them one time they are at the top and very strong.... I have bled the brakes the "old way" having a partner push the pedal, etc., and also have had them power bled.. Same problem..
The pedal does not sink to the floor when you keep it applied for a long time(used to be the test for a leaky master cylinder...).
All of the pads and rotors, and all of the calipers are in really good shape with no visible leaks---hoses and connections as well...
Any suggestions???
Old Aug 22, 2009 | 08:12 AM
Sounds like you are about to buy a new master cylinder. Rovers have always had a firmer pedal on the second hit but it sounds like yours is about to fail.
What brake fluid have you been using?
Old Aug 22, 2009 | 11:38 AM
Disrover's Avatar
8th Gear
Since I just got the Rover a few weeks back, I don't know----when I did the bleed, I used Prestone Dot 4 which carries the JMV designation...
After I bled them, I see BA recommends the Castrol GTLMA....
Old Aug 22, 2009 | 05:25 PM
You dont have to use the Castrol LMA brake fluid, thats what it came with, but you dont have to use it.
(Castrol is a British company so they want you to use British stuff, makes sense)
Old Aug 22, 2009 | 05:28 PM
lipadj46's Avatar
Prestone is really the only Dot 4 fluid I can find locally so that is what I use also.
TripleThreat
Dec 23, 2016 06:06 PM
EstorilM
Feb 24, 2011 01:52 AM
FightOnUSC79
Nov 26, 2010 09:43 AM
lipadj46
Nov 15, 2009 10:36 AM
saltyrover
Apr 4, 2006 05:51 PM
