2001 Disco 2 Service Engine Soon on
Old Jan 5, 2015 | 10:12 AM
DiscoShelt's Avatar
Default 2001 Disco 2 Service Engine Soon on
Whats up guys. I have seemed to run into another problem with my Disco 2 this time i was at a stop sign getting ready to make a left hand turn and my service engine soon light came on so i stopped to see if i could maybe hear something or see something under the hood it was dark out and i found nothing. On my way home i could tell she was hesitant when i pushed the gas and it felt like when i turned the light would start flashing again but she did get up to speed just hesitant and sluggish at first. Just my luck i guess the Autozone was open and i stopped and had them pull the codes. The first code is P0307 seems i have a misfire on cylinder number 7. Now i understand that this can be the cause of my spark plugs, vac leak, injector fault, or pressure issues how would i go about figuring out which one it would be? I checked my plugs they all seem tight and snug but i do have big *** hands. When i first bought the vehicle a couple of my plugs were snapped i got new spark plugs and cables and its been about a year and a half since then could it be my plugs ?. The second code the guy told me for some reason it popped up under a Subaru? i told him to give it to me anyway the code is P1590 probable cause open or short circuit condition, poor electrical connection, or failed neutral position switch. Any information would be useful as i will not be driving her untill i figure out whats wrong.
Old Jan 5, 2015 | 11:13 AM
drowssap's Avatar
i would start by switching the plug and wire, to see if the misfire follows.
Old Jan 5, 2015 | 04:15 PM
DiscoShelt's Avatar
OK, I will hop on that first thing in the morning should have word by the afternoon. I was thinking the same thing i'm going to change the plug and since i cant buy just one wire lol im going to change all of the wires and that one plug. Appreciate the fast reply man this whole forum is becoming a life saver.
Old Jan 8, 2015 | 05:31 PM
DiscoShelt's Avatar
Turned out to be an ignition coil after further inspection. I changed the plug and wires like you said still was missfiring on 7 I had a buddy run some test said it was the coil got that changed and im all good now. Thanks for your help
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
tdiddy
Jul 12, 2008 10:19 AM
RoverWild
Apr 13, 2008 07:17 AM
Memphy03
Jun 26, 2007 02:49 PM
bal51365
Dec 5, 2006 08:32 PM
