2001 Discovery 2 Transmission
Old Aug 26, 2020 | 09:11 PM
Eljefe2020$'s Avatar
4th Gear
Default 2001 Discovery 2 Transmission
Greetings, could someone help me figure this out, I don't believe the transmission is shot and it is some other problem.
Changed transmission filter and fluid problem remains. Problem is intermittent when put on drive sometimes the vehicle acts like the brake is on and hardly moves.
At times if I put in neutral and move the high low lever and re engage it to its original position in low gear and put it on drive the transmission grabs perfectly
Sometimes I have to try real hard time moving the high low lever and it does not engage. On the highway at speed it goes. Today it would not shift through the gears and stayed on one speed then is was fine again. I know one of the battery cables is loose and not attached correctly, got new Catalytic converters this is the only problem.
what could it be?
Old Aug 27, 2020 | 07:01 AM
Red5's Avatar
Morning and welcome. A lot going on here, and I don't follow some of it. Start with the battery cable, and all of the heavy cable connections for that matter. At the battery, block beside the alternator, starter, etc. Make sure everything is clean and tight and see what you have and post back.
Old Aug 27, 2020 | 10:43 AM
RoverPA's Avatar
Member
You need to reset adaptive values: disconnect both battery cables and leave touching together overnight. Your transmission will re-learn values next day.
Motorhead1
Dec 26, 2019 10:55 AM
bdac
Nov 15, 2010 06:47 PM
gsgtsg
Jan 5, 2010 05:32 PM
sn1987
Aug 15, 2009 09:17 AM
ElMaestro
Aug 3, 2006 11:38 PM
