2002 Disco 2 Transmission cooling system.
Old Oct 24, 2020 | 02:12 PM
anbran's Avatar
Default 2002 Disco 2 Transmission cooling system.
I've had a few problems with rusty "quick release" connections to the trans oil cooler. I've had one replaced with a rubber pipe and seems to work ok. My worry is if it happens again.
Contrary to pics I've seen of the trans cooler in front of the rad, my Disco has the inlet and outlet pipes on the driver's side (one above the other). It also seems that the cooler is in two halves. The bottom section is a bit wobbly, so I'm not sure if it's ready to let go?!
Would it be a good idea to completely remove the cooler and instal an aftermarket one (that are commonly called "auxiliary" transmission fluid coolers).?
Does anyone know what style my disco's cooler is?
Thanks
Old Oct 24, 2020 | 04:12 PM
anbran's Avatar
Disregard this post. (I've no idea how to delete the post)
bmeier
Dec 27, 2016 04:21 PM
LR03NJ
Nov 18, 2016 08:50 PM
evoblade
May 11, 2016 01:42 PM
stamper620
Apr 8, 2013 11:59 AM
javven
Jul 15, 2012 10:09 AM
