2002 Discovery II
Old May 30, 2011 | 03:22 PM
CohoJoe7's Avatar
3rd Gear
From: Live in Pittsburgh, PA but travel most of the year
Default 2002 Discovery II
I am a fly fishing guide and needed a vehicle for some old dirt back roads on the Delaware River. I just purchased a 2002, Discovery II with 45000 miles on it. The vehicle is very clean and so far, everything seems to work fine.
Is there anything I should know about this vehicle. (i.e. mechanical issues with this model or year) I have only had the vehicle a few days and I am very happy with it. I do need to get used to the large turning radius, especially with my drift boat being towed.
Looking forward to hearing from you folks and hope to share some great experiences with you.
Old May 30, 2011 | 03:48 PM
agthird's Avatar
run premium fuel and start hanging out here........
Old May 30, 2011 | 07:01 PM
DarylJ's Avatar
Check if the front drive shaft has greasable joints on it. If not, you should put a new one on. The stock ones fail and, if you are at speed, like to put a hole in the transmission. Stupid decision on LRs part, but easy enough to fix (if you get it before it breaks).
The weak point of these trucks is the cooling system. Watch your coolant level. Watch your temperature. Keep the system in good shape and you should be fine.
Old May 31, 2011 | 09:58 AM
Forrest's Avatar
Welcome fellow 2002 Disco owner,
I've have Forrest for about six years (now has about 88k miles) and he has never let me down! I've replaced or serviced everything but the only problems were I had to get new front drive shaft, take the sagging headliner out, and replace the leaking valve cover gaskets.
Just do normal maintenance and have fun.
C'ya,
Old May 31, 2011 | 02:55 PM
yloDiscoII's Avatar
Default Welcome!
X2 to above...change the oil on time, fix issues right when they come up, and most importantly don't overheat it....seriously, DON'T.
Read me ---> https://landroverforums.com/forum/di...st-read-26356/
...and then, post many pictures of your Disco whenever you're in the back-country so we can live vicariously through your adventures!
Old May 31, 2011 | 02:56 PM
sloan74's Avatar
45000 miles? Nice score man!
Welcome to the forums!
Old Jun 2, 2011 | 06:16 PM
CohoJoe7's Avatar
3rd Gear
Just wanted to thank all of you for your input. I am looking forward to running the back country up in the New York/PA border and will hopefully have some great things to share with you. Thanks again.
Old Jun 2, 2011 | 07:37 PM
DarylJ's Avatar
Between that and mentioning the Delaware it sounds like we might frequent the same places.
I hunt and shoot skeet at a club in Forestburgh NY. Great place for a Rover. You need it to get to some of the ranges.
jaysan21
Mar 12, 2014 12:59 PM
jaysan21
Mar 11, 2014 06:51 PM
Sqwanto
Apr 8, 2006 06:44 PM
mshudson
Oct 11, 2005 06:16 PM
Andy r
Jul 21, 2005 11:45 PM
