2003 disco issues
Old May 14, 2019 | 11:11 AM
Glsawyer's Avatar
Default 2003 disco issues
68k miles. Payed $500 for it. Didnt run...replaced crank sensor and started up. 3rd disco I've owned.
Issues:
1...alt puts out 13.78 at idle.
2...3 amigos.
3...intermittent flashing m,s and drive
4...was gonna replace xyz switch but when tried to pull linkage the put broke off.
5...due to rust the t case linkage is stiff so intend to replace with parts from a 96 so I can have diff lock.
Old May 14, 2019 | 11:12 AM
Glsawyer's Avatar
I'd like to swap over to something like a gm or Ford 1-wire 140amp alt...but not sure what would bolt on. Or if a 1-wire will still keep everything working right
Old May 14, 2019 | 12:20 PM
Best4x4's Avatar
P38 RR 99-02 Bosch = 150AMP alternator from the factory & bolts right in. 13.78 = good
Old May 14, 2019 | 03:40 PM
CollieRover's Avatar
Have you scanned the ecu for codes and the reason behind the m+s flashing?
Old May 14, 2019 | 03:52 PM
Glsawyer's Avatar
Yes. But it was almost a yr ago. And my scanner is busted. And no plates so cant take it in
Old May 14, 2019 | 04:02 PM
Best4x4's Avatar
Clean those terminals like a crazy person & make sure they’re tight!
Old May 14, 2019 | 05:25 PM
Pavilion's Avatar
Glsawyer where abouts are you? if your close I could bring my scanner by and have a look for ya.
Old May 14, 2019 | 05:26 PM
Ben Matheson's Avatar
Just did this fit fine
Old May 14, 2019 | 06:22 PM
Glsawyer's Avatar
Aberdeen wa. 98520
Old May 16, 2019 | 04:34 PM
Pavilion's Avatar
Originally Posted by Glsawyer
Aberdeen wa. 98520
Well in that case... I cant help ya. Sorry. be cheaper to buy a scanner and send it to ya. Ill keep thinking though and ask around see what I can hear.
NinjaPlease!
Jul 31, 2019 09:03 AM
Extinct
Oct 31, 2015 01:46 PM
texmanmoore
Apr 22, 2015 03:08 PM
hoov119
Jan 3, 2014 05:26 PM
Desiree
Feb 26, 2010 03:56 AM
