2003 Disco SE7 Tire Pressure?
Hey guys, just bought a 03 disco SE7 for some fun off road use. When I received the car it does not have the owners manual and wanted to know a couple things. The truck has the 18 inch split spoke wheels with 255/55 tires. What is the correct cold air pressure to run in the tires?
RE: 2003 Disco SE7 Tire Pressure?
ORIGINAL: Disco Mike
Read the sticker inside the drivers door jam and add 5 pounds to both the front and rear.
Be careful with the 18's off road, they are prone to little traction and sidewall tears.
Yes that is right. Because 18" tires have no sidewall you need them as full as possible, if they are aired down then you will increase the risk of sidewall damage.
Do what the door sticker says, no more no less.
If you are going to do more than dirt roads then dump the 18"s and get the 16"s.
You can look for used DII rims or used P38 (Range Rover late '90's to early 2000's) rims.
Brent Miles
03-02-2011 06:02 AM
DiscoMike2003
12-30-2008 05:52 AM
