2003 Disco, Smoke, Syrup Smell and Badly Leaking!
I was driving home last night, parked and shut off my engine and immediately smelled maple syrup. I was wondering if it was a neighbor but glanced back and started to see smoke/steam coming out from the hood.
Looked underneith and saw a lot of liquid dripping dripping and puddling underneith.
I cannot recall seeing or hearing anything different during my drive home and did not look at any gauges before I shut the car off. Nothing close to this has ever happened before this last night.
Any advice or forecast on how hard this is going to hit my wallet before I call the tow out? I've heard everything from head gasket to radiator.
2003 Disco V8 SE 79k miles
Thanks in advance
Thanks in advance
You are leaking coolant, it shouldn't be green, if it is, you are using the wrong one, should be Dexcool which is pink/orange.
Look at your coolant bottle, it is probably empty.
Do not drive it, sounds like you are not familiar with your engine or very mechanical so I would suggest you find a good Rover mechanic and have it towed to him.
download the RAVE manual. it will answer all your questions like where is this and what type of fluid does this take. http://www.landroverresource.com/
