2003 discovery II Cranks But No Start
Old Jul 12, 2022 | 09:49 PM
Rodsstang's Avatar
Default 2003 discovery II Cranks But No Start
I have a 2003 discovery II 4.6L cranks but no start. Cars Been sitting and battery was dead. Ran well when parked, Replaced Battery and used key fob to unlock vehical. Attempted lock and unlocking 3 times. Hood and all doors were closed. When locked, Security light flashes rapid for 10 seconds and returns to 1 flash per second after 5 seconds. Engine will start if sprayed with carb cleaner. So it has spark. Checked fuel pressure at rail (54 psi). After removing air plenum, Using Noid light checked for injector pulse. No PULSE! Using a DVOM, I Have 12.5 volts at injector connectors but no ground from ECM. I dont see where the ECM gets a ground in the RAVE diagrams, Is it a case ground on the ECM? Will a used ECM plug and play or will it need programming? How about if a get both the ECM and BCM, will that work?
What else have I missed? ANY HELP IS APPPRECIATED, THANKS, ROD
Old Jul 20, 2022 | 02:52 PM
Eduardo Castellanos's Avatar
Have you tried re setting the inertia button located the firewall in the engine bay on the passenger side. It is a black looking button.
Old Jul 20, 2022 | 03:36 PM
disco96sd's Avatar
That is a failed cank sensor down low behind cyl 7
Hudson#30
Mar 22, 2022 05:41 PM
humair
Nov 25, 2021 10:51 AM
Bwhitworth
Feb 25, 2020 01:13 PM
Hul1gan
Sep 27, 2016 09:10 PM
s928s
Dec 21, 2010 09:57 AM
