2003 Discovery Oil Pump Issue?
Old Sep 17, 2009 | 05:54 PM
  #21
If you replace the oil pump you must also replace the front engine cover.
Replacing the oil pump and front engine cover is a temp fix, it will fail again.
The problem is a block defect, the oil pump is housed inside the front engine cover.
The dowel pins on the front of the block that the front cover mates to are out of wack and they cause premature wear on the front cover which inturn puts premature wear on the oil pump.
So, the only 100% cure is a new non defective engine.
Your engine is still good, bearing and what not wise, just the oil pump will fail again.
Old Sep 17, 2009 | 07:18 PM
  #22
shonuff93's Avatar
do you think it will last another 90,000 miles or will it be quicker this time? And do you think that it is for sure a problem with that block of could it just be that the oil pump failed. Is every block within that vin set bad. I just thought that it would go before 90,000 miles if it were bad.
Old Sep 17, 2009 | 08:30 PM
  #23
IF it is a defective block ther eis no way it lasted 90k with the original oil pump.
They typically fail in the 40-50k range.
Not all '03's are in the bad VIN# range, not all in the range are bad and not all out of the range are good.
There are even a very small number of '04's with this problem as well.
So...I would to a oil pressure test, then depending on how that comes back would determine my next course of action.
It may have been a fluke.
Old Sep 18, 2009 | 10:45 AM
  #24
shonuff93's Avatar
Is that something that I can do myself or do I need a special tool. Im mechanically inclined, just haven't done that before. Thanks for all your help thats good news....
Old Sep 18, 2009 | 05:40 PM
  #25
Can you do it yourself? Ya, why not?
You will need to remove the front of the engine, thats the water pump, crank pulley, any belt tensioner, maybe the power steering pump and whatever else is in the way.
Unbolt it, remove the cover, install new oil pump, new front engine cover, water pump...you get the idea.
The only special tool that you will need it a fan clutch removal tool.
It is a 32mm nut that holds the fan clutch on.
Travelor
Sep 24, 2015 06:11 PM
Kingmarine
Feb 26, 2012 09:27 PM
Rovermike85
Aug 29, 2011 03:47 AM
LRScott
Jun 17, 2008 02:44 PM
Shryan
May 19, 2008 10:57 AM
