2003 knock sensor bank 1 low frequency
Old Nov 10, 2022 | 11:16 AM
bigred2929's Avatar
Default 2003 knock sensor bank 1 low frequency
Quick question. I have a bank 1 low frequency knock sensor code. I took a peak under there and it's covered in oil. I ordered a new one today. Would this also cause it to run rough? Anything else I should check while I'm t it other than the wires?
No other codes. 2003 disco 160,000 miles engine may have been replaced at some point?
Thanks
Old Nov 10, 2022 | 07:27 PM
bigred2929's Avatar
Default Update
I changed out the knock sensor today and everything seems to be ok now. When I went to remove the nut to take off the knock sensor the whole stud came out of the block. I believe it was loose to begin with. Probably my problem. Everything is ok now and is running a lot better.
Giorgier
Feb 5, 2020 03:12 AM
Rovergirl2001
Sep 15, 2015 11:27 AM
bshea992
Jun 7, 2012 01:41 PM
wlbannister
Aug 6, 2011 06:07 PM
jck09
Mar 22, 2010 10:10 AM
