2004 4.6 conversion?
Old Mar 9, 2015 | 10:20 AM
Alex_M's Avatar
I think the general consensus is that the '04 was the worst of the bunch because by that time the machining they were using was getting worn out so tolerances were all over the place. The '03-'04 had more sleeve problems and any of the 4.0s or p38 range rover 4.6s. If you aren't doing sleeves, the best bet would be a p38 block or a 4.0 out of a '99-'02. Someone please correct me if the bit about a p38 block working is wrong, but I'm pretty sure it will drop in fine.
Old Mar 9, 2015 | 11:05 AM
drowssap's Avatar
you are correct a p-38 block will also have a higher compression ratio
Darover
Dec 28, 2008 06:59 PM
LMannino
Oct 26, 2008 09:25 PM
spjoink
Mar 19, 2007 11:27 PM
hector5016
Nov 23, 2005 09:21 PM
kumbhani123
Apr 27, 2005 03:54 PM
