2004 blinking M&S P0600
Old Nov 30, 2013 | 03:30 PM
danboy's Avatar
Default 2004 blinking M&S P0600
Thanks to others sharing here I pulled the code P0600 and made my checklist. I tested fuses 12,21,24,25 all good. Battery voltage good, alternator good then got under the seat and found the root cause but I need help.
As I made sure the TCM had good connection I saw that some liquid got under there and corroded the plug. Take a look at the pics of my TCM and harness plug disconnected, 3 pins from the TCM are rusted and broken in the harness connector. I would like to know if I should try to get a junkyard harness and cut and splice or is the connector a replaceable part. If the connector is replaceable will I need to get a wiring diagram to make sense of it or is the inside of that connector color coded.
For the hell of it I called Rover and they can't wait to see me in this damm economy, they want $3900, over the phone quote without looking at the truck.
Attached Thumbnails 2004 blinking M&S P0600-imag1570_burst002_cover.jpg   2004 blinking M&S P0600-imag1577.jpg
Old Nov 30, 2013 | 06:02 PM
boyrover's Avatar
I would be tempted to find a parts vehicle and take the whole harness out. If that was too much trouble, I would get the multi plug and cut it off with a good amount of wire to spare (you can always trim the wire down later). I would then splice wiring one at a time, color to color. It looks like you might need to grab the TCU from the parts truck as well.
wolfgang528
Defender
Dec 28, 2010 04:25 PM
landRoverNewbie
Nov 30, 2010 05:39 PM
Arizona man
Nov 21, 2010 11:15 AM
rick.scott
Jul 4, 2009 12:01 PM
