2004 d2 se7 codes. 0134,35,0155,0705,0300,0301
truck is used have had it about a month. 2004 d2. blue wires. don't know how old. autolite double platinum don't know how old. 2 month old walmart 660 cca battery. previous owner purchased. truck has 90k. sometimes the truck will act as though it will stall. not all the time.maybe while sitting at a light. additionally I will get a blinking light every few days. I see it I let off the gas let it run its course and then everything is fine. any help would be awesome
getting codes
P0134
P0135
P0155
P0705
P0300
P0301
Where do I start
getting codes
P0134
P0135
P0155
P0705
P0300
P0301
Where do I start
yes my gear shift is acting crazy for some reason. when I put it in 3 I get the m & s blinks. then I have to reset it either pushing the mode button and then turn it off. and then for some reasom when I put it in drive the drive dots red one do not glow on the selector plastic. sometimes it will sometimes it wont.
as for miles it has 90k
where should I start on the 02's the pre 02's or the ones after the cat middle of truck
I got a couple different codes this morning, here is what my scanner pulled
p0705
130
135
171
154
p0705
130
135
171
154
705 is related to the XYZ switch on side of tranny, either out of adjustment or most likely full of crap to be cleaned out.
130 front LH bank O2 sensor out of range
135 - front sensor LH bank shorted or open heater circuit (check connector)
171 - LH bank outside normal fuel adjustment range (becasue of above codes)
154 - RH bank - front O2 sensor - no activity
Based on all that I would say that unless your are lucky and find connectors grimed up on the front O2s you'll be looking at two of those, mpg should improve.
XYZ switch may have to come off and be cleaned out.
RAVE download will include all these codes.....
hriant88
05-29-2008 07:31 AM
