2004 Disco 2 Engine Rebuild
Old Dec 21, 2019 | 01:21 PM
  #181
cvhyatt's Avatar
Default 12/21 Update
Now that I got the Disco running again, I am gearing up for a week of Rover tweaks. On the docket for this week:
  1. 2000 miles on the rebuilt engine. Going to use a borescope camera on each cylinder and see how they're doing.
  2. Replacing A pillar trim
  3. PCV mod
  4. Drop headliner and find and repair leaks
  5. Add rear sway bar extended links
  6. Find front clunk that occurs when going over speed bump.
Will post pictures as I go!
Old Dec 21, 2019 | 06:39 PM
  #182
cvhyatt's Avatar
Pulled the spark plugs to inspect them and also used a borescope camera to look in the cylinders. Spark plugs are white or rust colored which suggests they are running to lean or wrong plug. I am using NGK Iridium IX Spark Plugs BKR6EIX-11 plugs. What are other people using?
Not sure about the cylinders. They look ok but I’ve got nothing to compare them too. #6 looks like some oil may be getting past the rings. Thoughts? Anything to be concerned about?
Oh and no disco project would be complete by me if I didn’t screw something up. I cross threaded the #1 plug. Going to get a back tap tomorrow.
I
Old Dec 22, 2019 | 10:47 AM
  #183
XRAD's Avatar
The plugs are all fairly even which is good. Orange deposits can be normal or hot. Gap looks a bit big on some plugs, could be the angle. Need to check 02 sensor output rich/lean ratio while running and under acceleration.
Agree, a bit of oil in 6. rings or valve seal? Probably does not matter. Drive and enjoy.
Old Dec 22, 2019 | 01:52 PM
  #184
cvhyatt's Avatar
Default 12/22 Update
Waiting on the backtap to come in for retapping the #1 spark plug hole. While waiting I thought I would get started on @Best4x4 pcv mod. Getting the part tomorrow.
Back tap I ordered.
Removing the tube
Came off ok
Remaining plug in valve cover - wrapped it in electrical tape and some pbblaster and wiggled it out with vise grips.
Yeah, I’d say it’s clogged
Punching out the oil separator
Drilling out the tube
One end is ready to go. PCV valve should be here tomorrow.
Old Dec 23, 2019 | 03:25 PM
  #185
cvhyatt's Avatar
Default 12/23 Update
Made some progress on the disco today. Got the new A pillar trim installed. That was a pretty simple job of about 30 minutes.
Broken trim on passenger side
OEM trim
Cleaning up the drivers side.
Installed
Installed
Also used the back tap tool (everyone needs one of these) to repair the threads on #1. Worked great!
The back tap tool I used
Used a crow foot to remove one end of the SAI tubing
Slowing back tapping the threads from inside out.
Found some aluminum!
Now I am just waiting on the PCV valve to come tomorrow so I can finish up that mod.
Old Dec 24, 2019 | 02:24 PM
  #186
cvhyatt's Avatar
Default 12/24 Update
Finished the PCV mod. Truck runs great! Now onto removing the headliner and addressing those leaks!
Old Dec 29, 2019 | 11:06 AM
  #187
cvhyatt's Avatar
Default 12/29 Update
Raining here in Florida a lot which is turning my headliner into an aquarium. So here goes: removing the headliner to hopefully fix the sunroof leaks once and for all!
Getting there. Trying not to rush, label everything and be deliberate.
Headliner fully out
Old Dec 29, 2019 | 11:16 AM
  #188
Sixpack577's Avatar
Radiant barrier above it...you won't regret it.
Old Dec 29, 2019 | 02:01 PM
  #189
cvhyatt's Avatar
This thing was really trashed. Someone had sealed the glass and that seal was failing. As best I can tell, one of the drain tubes was leaking and the seal between the body and the sunroof frame was dry rotted.
I cleaned it up and added some flexiseal to the body/sunroof frame.
Heading to homedepot to get an adapter to help blow out these drain tubes and some radiant heat barrier for the roof. On track to finish up later tonight!
Had to use a power tool to separate the glass from the frame.
Old Dec 29, 2019 | 06:23 PM
  #190
cvhyatt's Avatar
Default Headliner Update
Made some good progress. Got the sunroof cleaned and resealed. Added to radiant barrier to the roof and got the headliner back in. Just have front seat belt pillars, dome lights and front trim to add back tomorrow.
