2004 Disco 2 Engine Rebuild
Old May 27, 2020 | 07:40 PM
  #331
cvhyatt's Avatar
Also made some new brackets for the LEDs so I could add them back to the bumper but not interfere with air flow.
Old May 27, 2020 | 10:13 PM
  #332
rhyslegge's Avatar
Originally Posted by cvhyatt
Finished the front bumper, changed the oil and upgraded the oil filter. Also retorqued the harmonic balancer bolt to 200lbs which was much easier than I expected.
Now onto the fenders!
next up
1) Fab New bracket for lights
2) Herucliner wheels
3) Herculiner roof​​​​​​
What method did you use to torque your balancer? I had my son hold the torquer, while I held a universal holding tool in those tiny little pin holes on pulley! I used the torquer to hold the pulley holder and we both pulled in opposite directions untilI the click happened. If you have a better method I'm all ears! I'm wary of using a windy gun, tho. Really enjoying the thread by the way!
Rhys Legge
Old May 28, 2020 | 12:26 AM
  #333
Discorama's Avatar
A minor project this evening but I was so impressed with the results I thought I would share with you all. Was watching a video about headlight restore products on project farm and this was their 1st place product in the category.
I did that 2 years ago. Just used sandpaper and
PLASTX PLASTX
and got great results. Unfortunately it starts fading again from parking in the sun. Next time I need to spray it with some UV protection.
Old May 28, 2020 | 06:32 AM
  #334
cvhyatt's Avatar
@rhyslegge I just put an extension and socket in the in the inspection port and torqued away! I spent more time trying to put the inspect port over back in place!
Old May 28, 2020 | 06:35 AM
  #335
cvhyatt's Avatar
@Discorama The sylvania prodtuct includes the UV protectant. Check out the video from project farm. They look at results under a microscope.
Old May 28, 2020 | 03:21 PM
  #336
Discorama's Avatar
What can I use for UV protection? I don't want to buy a whole kit, since I have the other stuff already. Some use clear coat, others a special UV protection fluid to wipe on. Which is better?
Old May 28, 2020 | 04:08 PM
  #337
cvhyatt's Avatar
You can just go by some clear coat spray with Uv protection
Old May 30, 2020 | 11:37 AM
  #338
cvhyatt's Avatar
Finished one rim. Used a lot more paint than I expected but I am happy with the results. Four more to do but first I have to finished fenders. Got them mostly done. Just need to add a few more coats of herculiner.
Clean and scuff
Prep for paint
First couple of light coats
Finished product
Old May 30, 2020 | 02:59 PM
  #339
cvhyatt's Avatar
Two front ones are complete. Just waiting for the duplicolor to cure before I put them back on. Found a cool tip from ChrisFix with the index card which is a whole lot easier than taping!
Prepped and ready for paint
4 coats of satin black and 2 coats of clear coat.
Old May 30, 2020 | 03:10 PM
  #340
Richard Gallant's Avatar
Nice job those look really nice
