2004 Disco 2 Engine Rebuild
Old Mar 7, 2021 | 09:48 PM
  #381
whowa004's Avatar
that spacer should work in the rear.
Old Mar 8, 2021 | 07:58 PM
  #382
XRAD's Avatar
Originally Posted by cvhyatt
Steering wheel had been cockeyed ever since I reinstalled the replacement steering box. Additionally, the steering wheel felt like it was slipping when turning. I figured I could kill two birds with one stone by loosening the universal joint & coupling set the steering wheel and re-torque in the bolt. When I went to re-torque the bolt I found that the bolt threads were stripped which probably explains the slippage. Another class 10 8x1.25 bolts with some blue Loctite and I was back in business. I love the easy wins!
had same issue. I passed a longer bolt through the clamp, and put a locknut on backside...
look forward to your F n R truetrac experience....
Old Mar 9, 2021 | 12:05 AM
  #383
COSPILOT's Avatar
This has been a good read for the thread I started on maybe buying and working on a 2003 I'm considering. Wow OP, good job!
Old Mar 18, 2021 | 07:17 PM
  #384
cvhyatt's Avatar
Default 3/18 Update
Finally got diffs w/ truetracs from GBR. Couldn’t wait so I had to open one. Gotta admit - I,be never unscrewed a package before!
Going to attempt the rear diff this weekend and see how it goes. Planning on using this write up. https://landroverforums.com/forum/di...nt-rear-78876/
Diffs came in pails. Genius!
Unbox - err unscrewing
Beautiful!
Old Mar 18, 2021 | 07:25 PM
  #385
MrHSE7's Avatar
So do you run those new differentials without traction control or with?
Old Mar 18, 2021 | 07:54 PM
  #386
cvhyatt's Avatar
These will run with the traction control. Using a lower gear ratio (4.11) with Detroit TrueTrac. Good write up here: Coil Sprung - Differential Carriers | GBR Utah
Old Mar 18, 2021 | 11:03 PM
  #387
MrHSE7's Avatar
Thanks for posting these updates. Ill be watching as it all comes together. 👍
Old Mar 19, 2021 | 10:06 AM
  #388
Tony Luna's Avatar
I love this thread...
Old Mar 19, 2021 | 08:30 PM
  #389
04disco2va's Avatar
Yes great thread. Wish we were neighbors ! Watching updates intently.
Old Mar 20, 2021 | 09:24 AM
  #390
cvhyatt's Avatar
Late start but here I go!
