2004 Disco hard starting/Random codes
If it's your fuel pump, you can diagnose this way:
Before going to start the vehicle, turn the key to position 2 and hold there for 5 seconds, then back to 0, then repeat 2 more times.
Now try to start. If it starts right up, it's your fuel pump. The sequence I suggested gets the pump to pump up the pressure before starting.
good luck
good luck
Felipe (10-02-2017)
Wow. Sorry about the CkPS, seems like it all the issues were related, But going back and read your initial post, you were getting 1174 and 1171. I had that not too long ago and I replaced all the injectors. Not only the O-rings were loose, it was saturated with liquids.
Please check out my last August and see how I fixed the issue.
HERE
https://landroverforums.com/forum/di...ocation-85169/
HERE
Do you have any recent codes? If you still have those injector codes, try using some injector cleaner with 93 octane gas. Thats a lesser evil than digging in there and check/replace the injectors or O rings. As far as we know you have an new CKPS. LOL! So we dont have to deal with that anymore. Cheers!
Felipe (10-03-2017)
krazzz
09-28-2009 10:38 AM
