2004 Disco hard starting/Random codes
Old Sep 28, 2017 | 01:56 PM
Felipe's Avatar
Thanks Garry,
I will tray the new CPS first to avoid any further codes confusion.
Old Oct 1, 2017 | 08:53 PM
Felipe's Avatar
I replaced the Crank sensor and still have the same issue with the starting.
Any other Ideas?
Thanks
Old Oct 2, 2017 | 09:24 AM
abran's Avatar
If it's your fuel pump, you can diagnose this way:
Before going to start the vehicle, turn the key to position 2 and hold there for 5 seconds, then back to 0, then repeat 2 more times.
Now try to start. If it starts right up, it's your fuel pump. The sequence I suggested gets the pump to pump up the pressure before starting.
good luck
Old Oct 2, 2017 | 09:42 AM
Felipe's Avatar
Thanks Abran,
I tried that already and didn't work for me.
Reading some treads I'm coming to the conclusion that could be a leaking injector.
Anyone can support me on that or knows a way to test for leaking injectors before I take them off.
Old Oct 2, 2017 | 10:05 AM
abran's Avatar
While it's running you can spray carb or brake cleaner all around under upper manifold in general injector direction. If the engine sound changes you have a leak.
Old Oct 3, 2017 | 12:07 PM
LR03NJ's Avatar
Wow. Sorry about the CkPS, seems like it all the issues were related, But going back and read your initial post, you were getting 1174 and 1171. I had that not too long ago and I replaced all the injectors. Not only the O-rings were loose, it was saturated with liquids.
Please check out my last August and see how I fixed the issue.
HERE
https://landroverforums.com/forum/di...ocation-85169/
Old Oct 3, 2017 | 01:53 PM
Felipe's Avatar
Thanks LR03NJ,
I was thinking along those lines... Where you also having issues with starting back then? or just the codes?
Old Oct 3, 2017 | 04:11 PM
LR03NJ's Avatar
Do you have any recent codes? If you still have those injector codes, try using some injector cleaner with 93 octane gas. Thats a lesser evil than digging in there and check/replace the injectors or O rings. As far as we know you have an new CKPS. LOL! So we dont have to deal with that anymore. Cheers!
Old Nov 8, 2017 | 01:11 PM
Felipe's Avatar
I finally found the hard starting problem to be a bad fuel pump. Even though it was a few moths old.
Thanks to everyone that try to help me.
Chapman Conti
Aug 28, 2013 06:36 PM
krazzz
Sep 28, 2009 09:38 AM
timothyfuqua
May 30, 2009 08:35 PM
martini7
Sep 22, 2006 08:18 PM
tover
Sep 20, 2005 11:57 PM
