2004 Disco II - Low Oil Pressure Light
Old Aug 20, 2013 | 06:45 AM
drowssap's Avatar
guessing, guessing and guessing. put a mechanical oil pressure gauge on it and see what you have really for pressure in psi hot and cold.
Old Aug 27, 2013 | 10:36 PM
jruproductions's Avatar
6th Gear
Just wanted to give everybody an update. After a week at the mechanic, we replaced the Oil Pump, gaskets for about every stinkin' thing - now running Shell Rotella T 15W-40 and a Napa 1068 filter.
New oil pump fixed it all.
Just installed a MotoRad 180 degree thermostat yesterday as well. She's running great! *Knocks on wood*
Old Aug 27, 2013 | 10:38 PM
dr. mordo's Avatar
Good news, and thanks for the update.
Old Aug 28, 2013 | 05:45 AM
drowssap's Avatar
"Why not remove the oil , hook up the mechanical gauge, and know for sure what is happening? Spec is 10+ at idle, and 50+ at 2500 rpm hot. Above 90F spec is use an oil that ends in "w40" or higher".
Old Aug 28, 2013 | 08:26 AM
Yep, if mechanic did not do a mechanical oil PSI test, was he skeered of what he might find???? After all that work, and I bet it was a lot more than the $112 for the pump and front cover gasket kit; without the test you still just know that oil PSI is above 7.
Old Aug 28, 2013 | 12:29 PM
earlyrover's Avatar
Default New oil pump, Thanks for update
111,000 miles, and a new oil pump needed; Why am I not surprised? They don't last forever, my friends! 180 deg F. thermostat too, is a very good thing. My inline 180 thermostat performs beautifully!
rewi9d
Apr 12, 2012 06:12 PM
eaglewing
Apr 16, 2011 11:06 AM
tito5590805
Oct 4, 2010 09:11 AM
DooDer
Jan 12, 2010 10:46 PM
houstonhelix
Apr 26, 2007 10:52 AM
