3 Amigos and Shuttle Valve Short to Ground
Old Jul 25, 2017 | 03:34 PM
twin6's Avatar
Default 3 Amigos and Shuttle Valve Short to Ground
Just changed out my Wabco modulator and shuttle valve after 3 amigos.
Shuttle valve electrical failure is the fault, when I drill down the scanner says Shuttle Valve shorted to ground. What gives? How should I troubleshoot. I removed the shuttle valve and I measured the resistance across the two electrical terminals. 3K ohms without one of the shuttle valve switches activated, 2.0K with either the left or the right side actuated and 1K ohms or so with both actuated at the same time so the actual switch is working.
Old Jul 25, 2017 | 03:50 PM
Victor Killbox's Avatar
7th Gear
Check out MPDano's thread @ https://landroverforums.com/forum/di...-so-far-85033/
Gotta say, it's pretty clever. Maybe it will help your problem.
austinlandroverbill
May 17, 2017 06:40 PM
bosshogt
Feb 2, 2012 06:52 PM
azoverlander
Mar 12, 2011 02:16 PM
meltdowndave
Dec 9, 2009 08:49 PM
wesk
Feb 17, 2008 10:22 PM
