340ft tourque wrench
Old Sep 25, 2012 | 06:22 PM
jfall's Avatar
You can bump it with no oil.
There is still an oil film on the crank and the journal surfaces.
If it starts, turn the key off fast.
Old Sep 25, 2012 | 07:32 PM
JasonjCook's Avatar
your right jfall.. i was looking at wrong spec. thanks for pointing that out. I have the v8 also..
so since the oil pan seal leaks as well .. going to do
oil pan seal .. front main seal ... timing chain seal .. new timing chain...
hopefully that will stop the BP protesters out on my lawn !
might have to find a new nickname for my Land Oiler 2000
anything else while i am in there that i should get ?
it has 179k on it .. thats why i am doing the chain ..
Old Sep 25, 2012 | 10:24 PM
Alan Phillips's Avatar
I recommend that you get yourself a 2x4 and use that to keep the crankshaft from rotating by wedging it between the crankshaft and the side of the block. You can use it when you loosen the crankshaft pulley bolt as well as to tighten it.
I just did the front cover, oil pan, front seal gaskets and found it to be the easiest method. You have to take the oil pan off to get to the front cover anyways.
2002 freebie se
Freelander
Jan 5, 2009 04:20 PM
roverboy
Dec 1, 2008 08:11 AM
ArizonaDisco
Sep 30, 2006 06:59 PM
bklahl
Jul 9, 2006 11:28 PM
FORDSTANGER
Jun 28, 2005 11:13 PM
