36mm Fan Wrench?..water pump replacement.
Old May 27, 2016 | 11:57 AM
GunnerandDeena's Avatar
Funny, now I don't hear it. Mystery. Maybe it all settled into place. Crossing fingers.
Thanks every one!
Old May 27, 2016 | 12:13 PM
chubbs878's Avatar
pinion/drive flange-holder, tool "LRT -51 -003" as seen on page 672 of the workshop manual, CNC-cut from .25-inch steel and constructed identical to the Land Rover tool.
http://www.landroverresource.com/doc...hop_Manual.pdf
Also cut from .25-inch steel, a 36mm wrench that is 25-inches long.
I made both of these to work on my Disco2, so they function perfectly. Message me an offer and in the meantime I will weigh and investigate shipping cost.
Old May 27, 2016 | 12:24 PM
cappedup's Avatar
Chances it was trapped air? That can sometimes sound a little bit high pitched and jingle like.
Old May 27, 2016 | 05:10 PM
jbarr89's Avatar
I can't recall at the moment but I'm sure someone here knows off the top of their head and it might help the OP or others, but is the fan reverse thread?
Old May 27, 2016 | 06:45 PM
dr. mordo's Avatar
No, it is not reverse thread. If the wrench is sticking up, you move it toward the passenger side to loosen the fan.
I personally use a huge adjustable wrench. I believe 40 mm is its maximum diameter. It just barely fits on the fan shaft and just barely sticks up enough to be manipulated, but it has the benefit of being more flexible than a fixed 36mm wrench. I keep it in my tool bag all the time, which turns out to be a good idea because my water pump recently failed when I was 600 miles from home.
Old May 29, 2016 | 11:35 AM
abran's Avatar
The secret to fan thread identification is to note which way the blades are pointing towards the radiator, that is the way to turn to loosen the nut. LR3s are opposite D2.
Old May 31, 2017 | 04:31 PM
MPDano's Avatar
That's an awesome tip, thanks!
Bkreutz
Dec 21, 2012 10:16 PM
lipadj46
Sep 23, 2009 04:49 PM
lipadj46
Sep 10, 2009 06:22 AM
SurfRat
Jan 12, 2009 04:20 PM
mooal5
Feb 17, 2008 09:01 AM
