4.6 Engine Build Code...
Old Sep 16, 2015 | 09:38 PM
iconoclast's Avatar
Default 4.6 Engine Build Code...
Can anyone on here tell me the internal engine model code for the 4.6?
(S54, BHF, M167 etc.)
Old Sep 17, 2015 | 09:52 PM
Alex_M's Avatar
I've never really heard of such a thing. I've only heard it referred to as a Rover V8.
Old Sep 18, 2015 | 06:01 AM
iconoclast's Avatar
generally there are internal code to designate the engine and engine management associated with each platform and to differentiate it from other vehicle installations. (when platform sharing has occurred.)
Old Sep 19, 2015 | 02:14 AM
abran's Avatar
Ive heard of people using the serial number to look up the motor on "a" database and find out if it's a 4.6 or not, but never heard of a designated code. Doesn't mean it's not there though.
If you are trying to identify a motor, drop the pan, the crank has 4.0 or 4.6 stamped on it.
Old Sep 19, 2015 | 09:41 AM
iconoclast's Avatar
i know it's a 4.6. no doubt about that but was looking for a code if LR/RR doesn't do this no biggie.
Old Sep 19, 2015 | 11:17 AM
Alex_M's Avatar
The closest thing cI an think of to what you're talking about is GEMS vs Bosch, but thats just for the engine management systems. All 4.6s are Bosch (factory, anyway), but not all Bosch engines are 4.6s; some are 4.0s and the Bosch engines were in both the P38 and the Discovery 2.
I don't believe LR does the designations like you're talking about though.
Old Sep 19, 2015 | 12:42 PM
iconoclast's Avatar
the more i research the more this seems to be the case.
Old Sep 21, 2015 | 06:11 AM
drowssap's Avatar
if a LR the comp. ratio stamped on the block will be like 9.15 if a RR it will be stamped about a 1/2 point higher closer to 9.75 comp. ratio. if that helps
Old Sep 21, 2015 | 01:06 PM
Alex_M's Avatar
Just out of curiosity, what do you want the build code for?
dusty1
Build Threads
150
Oct 12, 2016 10:12 PM
sayeedA
Nov 15, 2011 11:02 PM
mikec99rover2
Feb 21, 2009 08:33 PM
ajh
Dec 16, 2006 08:11 PM
ambishop
Audio/Visual Electronics
Dec 13, 2006 04:58 PM
