4.6/hp24 into 4.0/hp22
Old Jul 14, 2015 | 02:49 PM
  #131
dusty1's Avatar
I think the theory is; the rocker arm and push rods have been working together and are already fitted to one another. the rocker assembly will remain in its order (if you don't remove them from the shaft). they are left and right, there is no chance of them getting swapped, that way either. so with everything back from where it came, less chance or new wear or noise.
"if it ain't broke........"
Old Jul 14, 2015 | 02:50 PM
  #132
Charlie_V's Avatar
And yes, I am going to go ahead and get the Crower 229 cam. In fact I am going to do that right now.
Old Jul 14, 2015 | 11:15 PM
  #133
Charlie_V's Avatar
Default Finally to the Shop
Got everything off (but left the rocker assemblies on the heads, finger tight) and ready for the shop in the morning.
Uneducated view of things: crank bearings have visible grooves but corresponding crank portions look good. Probably just polish. Rod bearings looked good and smooth. Nothing looked copper colored. Sleeves were even.
I bagged and tagged each cap with its bearings and each piston with its bearings.
Old Jul 15, 2015 | 06:29 AM
  #134
dusty1's Avatar
man, that is one caked up lump
Old Jul 15, 2015 | 07:28 AM
  #135
Charlie_V's Avatar
For sure. I'm glad I didn't just put head gaskets on! Hopefully, the after shot will be much better.
Old Jul 15, 2015 | 12:26 PM
  #136
Charlie_V's Avatar
Default and now I wait
Shop has the engine, heads, crank, cam, caps, and pistons/rings. They're going to check the rocker assembly for me (left on heads).
Old Jul 16, 2015 | 11:53 AM
  #137
GROVERDISCO's Avatar
Default Cam
I didn't read the entire post but are you installing top hat liners? If not now would be a great time.
Old Jul 16, 2015 | 12:17 PM
  #138
Charlie_V's Avatar
Grover,
I am not installing them. The shop called and my liners are fine. I considered pinning them (and am still considering it), but the cost of machine work and flanged liners is better spent elsewhere within my budget. I've never had a problem with liners. Probably just jinxed myself.
Best,
Charlie V
Old Jul 16, 2015 | 12:33 PM
  #139
Charlie_V's Avatar
Originally Posted by abran
Oil pan off, wedge wood into crank, same on the stand as in the truck.
I doubt a strap wrench will hold it. I think the spec is 150ft lbs on the pulley bolt.
I hate to be sappy as well, but I have learned a ton from this forum. Thanks guys
Finally took the crank out and it worked just as you advised. The engine work is so much easier on the stand than on the truck.
Old Jul 17, 2015 | 11:36 AM
  #140
Default Liners
Originally Posted by Charlie_V
Grover,
Best,
Charlie V
It would cost you more to instal liners now, about $800 for liners and maybe $800 for machine work. I did my truck when it was apart and now never worry about the dreaded slipped liner. It's a lot of time to pull an engine to do what could have been done to have the ultimate engine just to have a new set of fancy tires and suspention lift a little sooner. Also how does your machine shop know the liners are fine? Did they heat the block and test? At the very least, pin it, your are spending a lot of money.
Best of luck!!
