4.6/hp24 into 4.0/hp22
Old Feb 1, 2016 | 06:30 AM
  #211
drowssap's Avatar
you can use 4.0 pistons with 4.6 rod and crank you gain about a 1/2-3/4 of a point.
unless you super man you did not bend that rod, that rod had to be swinging to get bent that way
Old Feb 1, 2016 | 09:13 AM
  #212
Charlie_V's Avatar
I'm definitely not superman but I did use a long bar turning the crank, or trying to turn it. The metal is confined to the area right around that piston, so I may indeed have broken the piston by brute force because the journal was wedged firmly against it. If you look at this picture on the right side of the piston that is a flat spot where it looks like the piston was shaved a few revolutions.
Dro, what do you mean by a point?
Old Feb 1, 2016 | 09:26 AM
  #213
Alex_M's Avatar
I believe he means less than a point. Half to three quarters. I'd say you'd be fine if that's the case.
I'm with Drow, no way you bent that rod. You'd have to be putting out more power than the engine itself is capable of producing without significant modification (ie forced induction on a lot of boost).
Old Feb 6, 2016 | 10:05 AM
  #214
Charlie_V's Avatar
New piston/rod and bearings arrived. Waiting for head gaskets, oil pump, and bolts. I'm off to the parts store for some brake cleaner to wash out the engine.
I am sorely tempted to reuse the head gasket and bolts that have 8 minutes run time on them!
Old Feb 11, 2016 | 11:39 AM
  #215
Charlie_V's Avatar
Just a quick update. Parts are in. Rebuild and transplant will be Saturday. I have the house to myself all weekend.
Old Feb 11, 2016 | 11:57 AM
  #216
drowssap's Avatar
hoping for better results this time
Old Feb 11, 2016 | 04:36 PM
  #217
Alex_M's Avatar
Fingers crossed. Did you end up using the 4.0 pistons or the 4.6 pistons?
Old Feb 11, 2016 | 09:34 PM
  #218
Charlie_V's Avatar
Thanks for the encouragement. I am at the piston choosing stage. Here is where I am.
Old Feb 11, 2016 | 09:45 PM
  #219
Charlie_V's Avatar
Default Bent conrod
You guys are right. No way I could have done this manually... I couldn't do this with a sledge hammer:
Old Feb 11, 2016 | 11:10 PM
  #220
number9's Avatar
Will be sitting on the fence before sending mine to you for a rebuild. Kidding aside, something out of the ordinary happened and not likely to occur again. Hope all goes good and looking forward to that news.
