4 quarts for a 97 disco transmission?
Old Apr 18, 2006 | 11:58 PM
awsherwo's Avatar
7th Gear
Default 4 quarts for a 97 disco transmission?
i was told 9 5/6 there is no way that is right
Old Apr 19, 2006 | 09:45 AM
Landzu's Avatar
Default RE: 4 quarts for a 97 disco transmission?
If you pull the drain plug on the transmission pan it
will take four to four and a half quarts of fluid.
Old Apr 27, 2006 | 07:58 PM
If in question, start with with 4 quarts, warm up the tranny and recheck the level and add accordingly.
Be glad you have one of the older trannys, from 99 on they didn't use did sticks.
Mike
Old Apr 27, 2006 | 11:25 PM
rovernbama's Avatar
8th Gear
Default No sticks
If from 99 on they do not have sticks how do you check the tranny fluid level?
Old Apr 28, 2006 | 01:28 PM
Default RE: No sticks
When warm and level, you remove the fill plug, if oil comes out you are OK, if not you are low.
Mike
QuakerJ
Apr 21, 2014 07:41 AM
me 2
Oct 22, 2012 07:54 AM
2000 DII
Oct 23, 2009 10:25 AM
piotrsuw
Jun 15, 2007 12:02 PM
doeboy
Sep 10, 2005 08:07 PM
