'92 disco - stalling problem while driving uphill
Old Sep 16, 2006 | 10:48 PM
pman's Avatar
6th Gear
Default '92 disco - stalling problem while driving uphill
My '92 3.5L petrol disco stalls on long (over 5 minute) uphill grind. The problem disappears after a 5 second wait on the side of the road. The problem only shows up on steady climbs. All sorts of solutions have been tried over a two year period. What do my mechanics and I not know about this or any car that has this problem?
Old Sep 17, 2006 | 10:11 AM
Default RE: '92 disco - stalling problem while driving uphill
So make life easier for us and tell us what has been done so far, save waisting your time with thoughts from us that you have already tried.
Mike
Old Sep 18, 2006 | 12:05 AM
pman's Avatar
6th Gear
1. Fuel and air filters replaced often
2. Fuel line flushed
3. New fuel pump and associated filter
4. New air mass sensor
5. Injectors removed and cleaned several times
6. New clutch
7. Several complete tuneups
8. New spark plug wires and destributor cap
9. New condenser
Old Sep 18, 2006 | 12:11 PM
Two things that come to mind would be a failing coil, fuel puimp relay.
Mike
Old Sep 18, 2006 | 04:56 PM
pman's Avatar
6th Gear
Thanks, Mike.
I failed to mention that I replaced the coil 6 months ago, but the 'fuel pump relay' sounds interesting. How could this pump affect the up-hill driving?
pman
Old Sep 18, 2006 | 06:22 PM
Under load, the pump has to work harder, if the relay is old, it won't take the starin and shut the pump off till it cools down. By the way, fuel pump relay are a pretty common issue with Discos.
Mike
Old Sep 18, 2006 | 07:43 PM
pman's Avatar
6th Gear
Mike,
What about the fuel pressure regulator (fpr)? A man at Rovers North said that the fpr may be the problem.
pman
Old Sep 19, 2006 | 11:39 AM
ORIGINAL: pman
Mike,
pman
That could be a possibility also.
Mike
Old Sep 19, 2006 | 04:04 PM
pman's Avatar
6th Gear
Thanks again, Mike.
I will have these two parts, the fuel pump relay and the fuel pressure regulator checked out.
pman
MrTortoise
Sep 29, 2017 02:37 PM
Lord Wert
Apr 12, 2013 10:44 AM
sabata
Sep 22, 2011 08:38 PM
mirko_gardilcic
22
Nov 3, 2009 10:49 AM
oldscoutII
Mar 25, 2008 08:54 AM
