'98 Disco wobble in steering
Old Sep 9, 2008 | 08:42 AM
Clunker's Avatar
Default '98 Disco wobble in steering
I have a 1998 discovery 1 that, when I hit a bump, shakes in the steering wheel. I have been told that this is caused by a bad power steering gear box. Does that sound right?
Old Sep 9, 2008 | 09:32 AM
Default RE: '98 Disco wobble in steering
I would have the tie rods and ball joints checked out first.
How much play is there in the steeing wheel? With the truck off and the wheels straight, turn the key on but do not start the truck, move the steering wheel from side to side.
Turn it as far left as you can before you feel resistance, then do the same going to the right. How far can you move the steering wheel? 1", 2" 3"? More than one inch to the left or right of center and the steering box is loose.
Old Sep 9, 2008 | 09:59 AM
sailorcolin's Avatar
It happened to mine and the only thing that was wrong was bad bushings in the shocks. It was a cheap fix.
Old Sep 9, 2008 | 10:31 AM
It can be from bad swivel preload, bad steering dampener any and all bushing, tie rod ends and the list goes on.
Is the truck still stock, how many miles on it?
Old Sep 11, 2008 | 11:04 AM
Clunker's Avatar
Thanks for the advice. I will have the ball joints and tie rods checked. There are no signs that anything else is wrong and have always maintained the vehicle. I hope it is a bushing! The vehicle has app. 130,000 miles.
Old Sep 11, 2008 | 11:24 AM
mh's Avatar
mh
I had the same problem on my 99 DISCO I.The whole problem went away when I replaced the ball joints and steering damper. Total Parts cost was about $250. It took me a day to the job, but if you know what you're doing, it will go much quicker.
Old Sep 11, 2008 | 12:24 PM
Clunker's Avatar
Yes, it is stock. I changed the steering damper first. It still wobbles. I am hoping it is a cheap fix. Unfortunatley, when it is a .50 fix or a $1500.00 fix I am the guy that gets the $1500.00. bill. Never have gotten the cheap fix on these vehicles. I loved my Range Rover 4.6 but, at 75,000 it became a joke.
super90
Jul 31, 2010 06:08 PM
Spencerfitch
Jun 26, 2010 11:02 PM
Rover Chris
Dec 12, 2009 07:53 AM
stephenibiza
Defender
Dec 2, 2006 05:36 PM
The Image
Sep 25, 2006 11:05 PM
