98 disco wont turn over
Old Jun 7, 2010 | 07:13 PM
driding's Avatar
Default 98 disco wont turn over
Ok, new to the disco world but bought A 98 disco 4.0 so it wouldnt be scraped! so here is the problem, when turning the key on, dash lights up... then upon hitting the ignition a click from the glove box area/ passenger floor board.. no startor movement at all. getting power to the ignition relays and getting power to the startor but no action??? any ideas would be a great help!!!
THANKS
Old Jun 7, 2010 | 07:52 PM
Rearden Steel's Avatar
Have you downloaded the Rave Manual?
Rave Manual http://www.landroverresource.com/
Old Jun 7, 2010 | 08:09 PM
driding's Avatar
no i havent, but will do shortly. thanks
Old Jun 7, 2010 | 08:58 PM
First check your battery and make sure it is good.
Then with a voltmeter check the power at the starter, replace the battery cables if needed, this is common for the cables to corrode and the starter not get enough juice.
You need to read through this too, there is ALOT of info in there, spend the time, seriously.
https://landroverforums.com/forum/sh...ad.php?t=26352
Old Jun 8, 2010 | 06:16 AM
antichrist's Avatar
Don't just focus on the battery to starter cable either. You need to check the entire circuit.
Battery to starter
Starter to chassis ground
Chassis ground to battery
If your fuse box to battery cable (and alternator to fuse box cable) is not tight and clean, or your battery to chassis ground it not good, your battery may not be getting a full charge.
Old Jun 8, 2010 | 10:31 AM
AK Rover's Avatar
It sounds like you have checked all your electrical so it's time for something mechanical. Climb under the truck with a hammer and give the starter a few taps. Sounds like your starter is just stuck.
sblankenbehler
Mar 30, 2015 06:42 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
cbritt
Oct 13, 2009 07:23 AM
cellman01
Jul 28, 2009 06:44 PM
tryinthis2
May 22, 2008 09:35 AM
