99 disco Water Pump?
Old Apr 30, 2008 | 05:45 PM
pc jamie's Avatar
Default 99 disco Water Pump?
Hello
I am a new Land Rover owner.
I just bought a 99 Disco as a beach vehicle for the family. When I start it, it makes a squeeking sound from the fan area. I went under the truck anddiscovered some anti freeze on the bottom of the motor. Not dripping just wet. I am starting to think that I have a water pump problem. Has anyone experienced a simular problem? If so is a do it yourself job or should I find a mechanic?
Old Apr 30, 2008 | 06:24 PM
KeizerRover's Avatar
Default RE: 99 disco Water Pump?
If you are mechanically inclinded, it isn't that big of a thing. Get a copy of the RAVE CD, I think the link to download it is www.green-oval.com, and there are rather good detailed instructions there.
Old Apr 30, 2008 | 07:02 PM
okdiscoguy's Avatar
do you have a D1 or D2? D2's have the higher tail lights and the engine looks like it has a bunch of tubes all around. relatively easy on both, but a D1 is easier. I would replace the fan clutch while you are at it.
Old Apr 30, 2008 | 08:29 PM
Alldata bills it as a 1.2 hour job, so it might take you two hours.
Do not buy a Proline water pump, they are junk.
Old Apr 30, 2008 | 08:40 PM
You better get the coolant system pressure tested to vefify the leak,
also if the pump is bad, replace the hoses, t/stat, both idler pulleys and the belt tensioner along with a new belt.
A5scott
May 18, 2015 06:34 AM
discoboy
Dec 20, 2012 02:24 AM
Savannah Buzz
Jul 21, 2011 08:02 PM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
