Mix-n-match brake rotors?
Old Apr 30, 2008 | 07:18 PM
meltdowndave's Avatar
Default Mix-n-match brake rotors?
Initially, I thought that I needed 4 rotors for my '03 Disco (49.5k).
After looking at them more carefully, it looks as though I only need front rotors.
Would it be acceptable to, say, replace the front rotors and pads with EBC units while leaving the rear rotors and pads alone?
When the rear rotors are due, I'd upgrade them as well.
Old Apr 30, 2008 | 08:38 PM
CandiMan's Avatar
Default RE: Mix-n-match brake rotors?
ORIGINAL: meltdowndave
Yes
Old Apr 30, 2008 | 08:42 PM
Ditto, the trk doesnt care, as long as you use the same brakes or rotors on the same axle.
Old Apr 30, 2008 | 08:53 PM
Thanks!
Someone in another thread brought up the slotted/drilled Proline rotors. They can be had for $110 per set from Rovers North.
Anyone got anything to say about them?
Old Apr 30, 2008 | 08:57 PM
Do you off-road? If so dont use drilled and slotted rotors, then can fill with mud and cause problems.
As far as stopping goes, they are great. They will shorten your stopping distance.
Old Apr 30, 2008 | 09:08 PM
A lot more highway than off-roading.
The extra stopping power and the cost makes them a no brainer.
Thanks!
sideshow
Mar 7, 2019 09:48 PM
bcolins
Sep 14, 2015 01:10 PM
aftermath431
Dec 24, 2014 04:25 PM
disc oh no
Aug 28, 2011 05:36 PM
HE_CPT
Oct 13, 2010 02:04 PM
