ABS
Old Jan 9, 2008 | 02:29 PM
Bulldogs_1789's Avatar
4wd High
Default ABS
Ok, so havin a little trouble with the ABS. been through the entire checklist...valves in the modulator dont seem to want to function, motor runs...but nothing happens, any ideas?
Old Jan 9, 2008 | 04:48 PM
okdiscoguy's Avatar
Default RE: ABS
There is a kit to re-buid the shuttle valves, or you could replace it. www.roverland parts.com has good prices on used stuff..
Old Jan 9, 2008 | 05:58 PM
Default RE: ABS
Have you actually had the codes read? What year is the truck?
Old Jan 12, 2008 | 03:56 PM
4wd High
Default RE: ABS
had them read, says something about a ground fault with the ECU or ABS brain...cant remember which, its a 2001
Malafax_Dand
Mar 30, 2009 06:31 PM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
