ABS
Old Dec 6, 2008 | 06:43 PM
DDP's Avatar
DDP
Default ABS
PLEASE HELP ME UNDERSTAND WHAT TO DO NEXT, ABS LIGHT IS ON, I REMOVED THE FUSE THIS STOPPED THE PEDAL FROM TRYING TO READJUST ,,,,,,, SO OW WHAT HOW DO I FIX
1998 LR DISC,
Old Dec 6, 2008 | 08:41 PM
Default RE: ABS
So what are you trying to fix?
Can you be more specific on your problem?
Old Dec 6, 2008 | 09:12 PM
DDP's Avatar
DDP
Default RE: ABS
THE LIGHT STAYIN ON AND THE PEDAL TRYING TO ADJUST ITSELF I HEAR A PUMPMOTOR SOUND WHEN THIS HAPPENS
UNTIL I REMOVED THE FUSE
Old Dec 6, 2008 | 09:21 PM
Default RE: ABS
Ok, now we are getting somewhere.
Your brake pedal isint trying to "adjust" itself, that is your ABS pumping the brakes.
This is a common problem on older, wait, their all old, thats why they are DI's.
This is a common problem on DI's, you will need to replace the fuse and have the ABS codes read by a Land Rover shop, unless you dont care about having anti lock brakes, then just leave the fuse out and dont worry about it.
The ABS light will stay on until the bulb burns out, and I can tell you that the ABS bulb is the longest lasting and best built part of the truck. That bulb lasts forever.
I pulled my fuse two years ago.
Old Dec 6, 2008 | 09:48 PM
hazletbassist89's Avatar
Default RE: ABS
hahaha Spike, are you sure some of the components designed to last 2-300k miles aren't a little better built than the ABS bulb?
Malafax_Dand
Mar 30, 2009 06:31 PM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
