ABS
Old Jan 13, 2009 | 11:16 AM
davidcampy's Avatar
Default ABS
I have a 2002 Disco and recently lost my ABS. I've had the three amigos for a couple months, but still had traction control and ABS. I can just about live with the dash lights, but with the winter in Chicago, I need the ABS. The only dash indication is the brake light is now illuminated. Can anyone help? If I can get this fixed, then I will ask about the 3 amigos, why my cruise doesn't work (vacuum hose loose?), and where I can get a deal on a rear window motor. Thanks folks...
Old Jan 13, 2009 | 02:39 PM
Default RE: ABS
Chances of you having ETC with the 3 Amigo's on is slim to none.
You need to have a good qualified Rover mechanic, read and clear the codes to see if they stay off, if they don' then you start throwing parts at it.
As for your cruise control, there are 3 or 4 vacuum lines you need to inspect and replace as necessary to get things working again.
As for the wiper motor, contact, Roverlandparts.com they have good prices and a guarantee.
Old Jan 13, 2009 | 05:58 PM
Default RE: ABS
Your RED brake light came on?
You are low on brake fluid.Go and buy some TONIGHT, take the wifes car, do NOT drive the Rover until you top off the brake fluid resevoir.
Old Jan 18, 2009 | 11:10 AM
davidcampy's Avatar
Default RE: ABS
Thanks Mike and Spike. I appreciate the comments. To elaborate (Spike) The brake fluid reservoir is full. Could it be anything else? I'm at a loss. Mike, despite the fact that I have the 3 amigos, the ABS was still working until a few weeks ago. I'm working in Chicago for the time being and we have plenty of ice to test it on. When the ABS stopped working, it coincided with the red brake light illuminating. I am going to take it to someone, but the mechanic (USAF jets) in me wants to know what's going on ahead of time so I don't get overcharged. As far as the cruise goes, does anyone have an exploded diagram of the cruise system? Thanks for all your help, David
Malafax_Dand
Mar 30, 2009 06:31 PM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
