ABS Amigo problem
That is the code for your shuttle valves and ABS modulator. the repair can be found in the sticky ABS modultor fix. Before you dive into the whole fix, make sure you check the ground bolts for the ABS. They are in lacated in the front of the engine compartment, by the air filter box. That was part of my problem. If your disco is like mine, you will need the whole kit from falconworks:ABS shuttle valve code solution; brake fluid leaks
Good luck.
Good luck.
