ABS Amigo problem
Old Mar 22, 2012 | 08:40 AM
Disco00's Avatar
4th Gear
Default ABS Amigo problem
Bought ABS Amigo from RSW, registered code 114 "shuttle valve electric failure", what's the fix. Are these codes universal for disco2 diagnostic device or proprietary to ABS Amigo? Who knows.....
Old Mar 22, 2012 | 08:44 AM
Contact Storey at RSWsoultions and get the code help you need.
Old Mar 22, 2012 | 03:48 PM
matt3502's Avatar
That is the code for your shuttle valves and ABS modulator. the repair can be found in the sticky ABS modultor fix. Before you dive into the whole fix, make sure you check the ground bolts for the ABS. They are in lacated in the front of the engine compartment, by the air filter box. That was part of my problem. If your disco is like mine, you will need the whole kit from falconworks:ABS shuttle valve code solution; brake fluid leaks
Good luck.
lipadj46
Apr 13, 2017 04:51 PM
yuenie
Jan 13, 2010 05:37 PM
Princess
Jul 4, 2009 12:24 PM
Malafax_Dand
Mar 30, 2009 06:31 PM
