ABS Amigo results...
so here are the results of the ABS Amigo reading from the truck...
|* ABS Amigo Box V1 RSW Solutions LLC Copyright 2008. *|
|* Welcome to RSW Solutions *|
|* Version V1.1 *|
1.--Current Faults---->
Active Faults:
None
Logged Faults:
None
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
046:Front Left sensor output low
Front Left Sensor Bad Output
<-END Faults
Active Faults:
114:Shuttle Valve Electric Failure
Logged Faults:
020:No batt supply voltage
021:Engine PWM signal bad
023:Gear info not valid
064:Front Right sensor electric fail
065:Rear Left sensor electric fail
066:Front Left sensor electric fail
067:Rear Right sensor electric fail
<-END Faults
who can help me decipher what is relevant and what isn't from that? should I just be focusing on the left front sensor? lube it? replace it?
your help is appreciated!
|* Version V1.1 *|
Active Faults:
None
Logged Faults:
None
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
Logged Faults:
<-END Faults
well, they were on. then I Amigo'd them and they were off. then I drove about a block and got the 3 bells, and the Amigos rode back into town.
what's the 'triage' here? lube the sensor/hub thingy - - replace sensor/wire - - replace hub? that about the look of it?
In the past it would appear that the ABS system has suffered a shed load of coded faults although not currently applicable ................ I think/hope.
Yep, you're right, never crossed my mind it could be from the previous punters readings.
Mine has a lot to say.....
|* Version V1.1 *|
Active Faults:
None
Logged Faults:
014:Pump fail pump sticking
022:ECU Gnd or Reference Gnd bad
033:Front Left out valve open circuit
035:Rear Right out valve open circuit
040:Pump relay open circuit
044:Front Right sensor output low
045:Rear Left sensor output low
047:Rear Right sensor output low
Front Right Sensor Bad Output
<-END Faults
Active Faults:
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
|* Version V1.1 *|
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
|* Version V1.1 *|
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
|* Version V1.1 *|
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
seaosrover
Oct 23, 2010 01:48 AM
