ABS Fault
Old Apr 2, 2025 | 05:20 PM
redrover75's Avatar
Default ABS Fault
I get the below from the ABS Amigo, I have done the option B. I certainly could have screwed it up, the ground looks good to me. Any other way to test it before I pull the unit apart again?
logged Faults:
114:Shuttle Valve Electric Failure
I also get the below which leads me to think the RR hub is bad. I get the fault very intermittently, I know I should swap the sensors to see if it moves. Does the 020 mean anything?
020:No batt supply voltage
047:Rear Right sensor output low
Sometimes, less frequenlty, I get these:
012:Pump fail monitor line
035:Rear Right out valve open circuit
040:Pump relay open circuit
Thanks,
Old Apr 2, 2025 | 09:14 PM
Brandon318's Avatar
Whenever I've had a bad hub, it's always accompanied with the "Rough road, signal implausible" code.
I'd back track all your Option B connections. It's truly the easiest (and free) of the troubleshooting options.
(and obligatory "make sure your battery is fully charged" mention)
Old Apr 2, 2025 | 11:06 PM
JohnZo's Avatar
Prior to OBD2, a code 02 meant the battery had been disconnected. Maybe relates to the 020 question.
Old Apr 7, 2025 | 10:26 AM
redrover75's Avatar
Ill pull apart the option b and see what I have. Somewhere I have the info on testing it, the voltage, etc when the valves are actuated.
Cpashley1
Oct 15, 2024 02:26 PM
redrover75
Apr 21, 2024 07:08 PM
redrover75
Feb 24, 2022 02:53 PM
redrover75
Oct 7, 2020 03:32 PM
Lupin 3rd
Nov 27, 2012 12:34 PM
