abs fix
Old Nov 10, 2014 | 04:10 AM
scarpinatore's Avatar
6th Gear
Default abs fix
Hi all,
I uploaded the three pdf files with all the images.
Disclaimer: The files have been produced by maui27 of the africaland.it forum, thanks to him for the effort and sharing!
File Type: pdf
File Type: pdf
File Type: pdf
Popular Reply
Nov 10, 2014, 04:10 AM
scarpinatore
6th Gear
Default abs fix
Hi all,
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 7, 2015 | 09:28 PM
dusty1's Avatar
another useful one
Disco ABS Fault
Old Feb 9, 2015 | 08:16 PM
dusty1's Avatar
Default abs fix
most of the original is gone, but a couple of guys put up some decent info.
figured it would be helpful to put the good stuff here and not have to look through the dead links
newly addressed thanks to Josh
http://landroverclubvi.weebly.com/
Old Jan 22, 2019 | 11:27 PM
Sito's Avatar
Thanks for such a good job. I have a doubt, the lights disappear but the traction control is still in operation and it helps the descent?
Thank you.
Old Apr 6, 2020 | 06:21 AM
RoverSE7's Avatar
does bypassing the shuttle valve make the ABS system in operative?
Old Apr 6, 2020 | 06:45 AM
ahab's Avatar
You're not bypassing the shuttle valve. You're renewing a source of ground which enables the switches inside the shuttle valve to function correctly. ABS is not in any way compromised.
Old Apr 6, 2020 | 07:06 AM
mln01's Avatar
No, as ahab said this fix restores full ABS operation. It bypasses a faulty printed circuit board in the ABS module; it does not bypass the ABS system.
Be sure to do Option B. There is no need to disconnect any of the brake lines. Please ask if you have any more questions.
Old Apr 6, 2020 | 07:45 AM
RoverSE7's Avatar
Thanks guys you are invaluable !!!
Apestit
Sep 11, 2017 07:11 PM
countryman
Jan 21, 2017 02:18 PM
Stephen Disco 2
Dec 16, 2015 11:42 AM
30more
Nov 12, 2015 11:10 AM
drakenkade
Dec 19, 2010 01:28 AM
