ABS problems
Old Nov 11, 2015 | 01:13 PM
30more's Avatar
Default ABS problems
I have a code reader. so far what I have is all four lights, emergency brake light, hill descent, abs, traction control are on. First time it happen all 4 lights. This is what happened, i push the gas traction control light comes on feels like gearing slowing down or grabbing. Went off come back on did the same thing felt like brakes sticking or something like that. Then all four lights came on. Read my code. So far all I've gotten is pump failure / sticking. What are you guys thinking my problem is and how to permanently fix it?
Old Nov 11, 2015 | 03:50 PM
Titus's Avatar
When the ABS module senses a fault it decreases power to the engine so that likely explains the feeling of slowing down.
Old Nov 12, 2015 | 09:56 AM
mln01's Avatar
I've never seen this suggested in any forum, nor can I find any mention of it in RAVE. Where is this documented? What is your source?
Old Nov 12, 2015 | 10:10 AM
drowssap's Avatar
it made you think
Old Nov 12, 2015 | 11:10 AM
30more's Avatar
Clear code yesterday. So today driving around the block same thing traction control light and then three amigos eventually. Checked codes right sensor front low output. I then checked the outputs. Front left 2.21 front right 2.17 Rear were both 2.19. I'm guessing I have a bad sensor anyone else concur I will keep checking codes
Malafax_Dand
Mar 30, 2009 06:31 PM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
