ABS fuse
Old Oct 14, 2009 | 01:35 AM
  #21
Rover Chris's Avatar
I agree with Spike, mine was the same way only disabled the ABS. I would think you may have the wrong fuse, or it is a very strange coincidence that your heat fan went out at the same time.
Old Oct 14, 2009 | 10:28 AM
  #22
dashizzzkat's Avatar
4th Gear
it is very strange. i tried both fuses too, the abs valve and the abs pump. one at a time with same results.
Old Oct 14, 2009 | 04:16 PM
  #23
I pulled the 30A ABS pump fuse and have had no problems.
Old Oct 14, 2009 | 04:50 PM
  #24
maybe a stupid question but if you plug the fuse back in the fan works?
Old Oct 14, 2009 | 09:26 PM
  #25
Eurotrash's Avatar
Pull the ABS pump relay on the fuse box under the bonnet.
Old Oct 15, 2009 | 04:00 PM
  #26
alanroberts50's Avatar
For anyone interested in reading their own ABS codes on a 97&98 D1 you only need to insert a paper clip in the ODB. (bridge pins 5 & 15). There is a "blink" system. The amount of blinks of the warning light correspond to the codes. You can find it in the archives. Earlier D1s had a separate blue, 4 pin ABS connector that you can read in a similar fashion.
Alan
98D1
Blakesrover
Feb 21, 2013 01:43 AM
Rover Chris
Jan 3, 2013 09:17 AM
DiscoStuart
Dec 23, 2011 08:32 AM
ESPN
Sep 20, 2011 07:55 AM
lowill
Mar 14, 2007 05:01 PM
