ABS ?s
Old May 14, 2009 | 12:33 AM
crainb45's Avatar
Default ABS ?s
If I unhooked the abs sensors on my 95 disco will it be that big of a deal? Is it a major issue with safety? Just wondering since I'm a little new at discos
Old May 14, 2009 | 12:54 AM
98roverguy's Avatar
Don't unhook the sensors. Pull the fuse(s) under the hood. Remove the bulb from your console. No harm other then no ABS. Let me know if you need help. Of course when you sell it, be honest...
Old May 14, 2009 | 12:56 AM
AK Rover's Avatar
It's easier just to pull the fuse for the ABS pump under the hood. It's safer to disable to the ABS than to drive with it malfunctioning. The brakes will still work but you obviously won't have ABS so just keep that in mind on slick roads.
Old May 14, 2009 | 09:05 AM
First before we all make a suggestion, what are your brakes doing??????????
Malafax_Dand
Mar 30, 2009 06:31 PM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
