abs sensor prob at drum
Old Sep 21, 2011 | 05:25 PM
mwood2121's Avatar
Default abs sensor prob at drum
Ok, wasnt getting much attention with my other post. Changed out the sensor and it cleared the 3 amigos. Problem is traction control comes on at about 25-30 mph and when I turn sharply. I took the wheel and things back off and noticed that the where the sensor plugs into the drum is kind of gritty. What can I clean that with. Obviously I wouldnt spray anything in it but could I just clean it with a q-tip or compressed air or something? any help would be appreciated!!
Old Sep 21, 2011 | 07:48 PM
jafir's Avatar
Drum? Do you mean the hub assembly? Are the bearings loose? If compressed air doesn't clean it out, I'd probably spray it down with something before I replace it. Those hubs are pricey.
Newbie1989
Jan 17, 2011 07:32 PM
transpartstech_rover
Mar 2, 2010 02:13 PM
roverboy
Jan 27, 2009 06:37 PM
scubaman
Oct 12, 2008 12:52 AM
