ABS Sensor Question
Old Dec 24, 2018 | 02:40 AM
The Deputy's Avatar
Yeah, l wish folks would follow up with information...whether it was fixed or not.
​​​​​​​ Brian.
Old Dec 24, 2018 | 08:42 AM
Chemcorp158's Avatar
Default Sorry didn’t update
i replaced the hub and it didn’t seem to fix it. Code would reappear within about 200 feet, so I drove with the amigos on for about a month and on a whim cleared them and they haven’t been on since. I don’t understand why it took a month of driving to decide it liked the new hub and sensor, but I am happy it’s gone. Now if I could fix the slow leak on the transmission all would be grand.
Old Dec 24, 2018 | 10:04 AM
The Deputy's Avatar
Thank you, for the follow up info. Regardless of outcome, it's nice to hear.
Brian.
Old Dec 26, 2018 | 05:13 AM
stxscott's Avatar
After replacing my ball joints I had a bad sensor code on my right front. I purchased a new sensor but when I went to install it the existing plug/socket in the engine bay disintegrated. I tried inserting the connectors as best I could to the damaged socket it but still had the code issue. I then trimmed the wires (skinny little buggers) and wired it up, but still the code persisted.
I broke down and bought a complete hub. I got one of the cheap ones on E-bay as noted above. I installed it and cut off the connector, hard wiring it using crimp connectors and heat shrink tube. This fixed the problem. I have a scanner that can read/reset the codes which was invaluable in tracking down and resolving the issue.
Chemcorp158
Jun 17, 2018 06:13 PM
ukwildcats
Jul 13, 2013 07:30 PM
FLRover
Aug 1, 2012 10:50 AM
Disco2001
Sep 13, 2011 07:12 PM
