ABS / TC noise
Old Mar 29, 2010 | 02:07 PM
boxerboy2's Avatar
Default ABS / TC noise
I have a noise that sounds like a snare drum comming from the drivers side of the engine compartment. It occurs when I hit a certin type of bump in the road and when the TC kicks in so I beleve it is associated with the ABS/TC unit.
Do I have a problem or is this just normal?
Thanks!
Old Mar 29, 2010 | 02:32 PM
lipadj46's Avatar
When you go over a bump our TC/ABS may engage.
Old Mar 29, 2010 | 03:25 PM
salve7's Avatar
Mine clicks and whirrs but is not as loud as a snare. I would say that if its working, its fine though.
Old Mar 29, 2010 | 03:36 PM
csbd's Avatar
Hadn't thought about it but, "snare drum" is an apt description, though certainly not loud. I consider it an auditory reminder everything is working as it should.
Old Mar 29, 2010 | 04:42 PM
boxerboy2's Avatar
It took me awhile to come up with an accurate description and then I saw/heard a snare drum on the tele and that was it.
30more
May 28, 2012 05:01 PM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
