AC temp from vents
Old Aug 2, 2023 | 10:31 AM
brooksa's Avatar
Default AC temp from vents
Had the driver side cooler than passenger side issue so checked pressure on system and showed it was low. I put some R134 in and def made a difference in both side temps, long drive 95 degrees I saw the drivers side temp drop to 43.9 and passenger still lagging behind at 49-50 degrees. My first question is what temp out of vents is considered good and satisfactory?
So today I checked pressures again (pic attached) and high side was pushing 200 and from the r134 chart it would be on the high and over what the chart says and low side was within the 35-45 range. Anyone with more AC knowledge than me tell me did I overcharge the system that might be causing the different temps?
Parameters of when I checked pressures this morning, outside temp was 75 and muggy, ac on max with recirc on and truck up to temp at idle.
75 outside temp, AC on max with recirc and truck up to temp
Thanks
Old Aug 2, 2023 | 06:16 PM
Extinct's Avatar
I posted a similar thread, you may have a plugged expansion valve.
Old Aug 2, 2023 | 07:40 PM
brooksa's Avatar
I did see your post, did you replace the expansion valve?
Is this a remove the dash repair?
Old Aug 3, 2023 | 06:08 AM
Extinct's Avatar
No and yes. Luckily I live in a relatively moderate climate where less than optimal ac is probably ok. Maybe I will do it someday.
Gonow
Jun 29, 2023 04:10 PM
Mo1313
LR2
Jun 28, 2021 09:02 AM
landroverdude
Aug 21, 2019 10:45 PM
Drake Anderson
Jul 10, 2019 01:35 PM
LRtoo
LR2
Jun 26, 2016 05:06 PM
