Accomplished the Option B Amigo Fix today
Old Dec 12, 2010 | 05:40 PM
texmbr's Avatar
Default Accomplished the Option B Amigo Fix today
Had bleed the brakes on our 01 SE with 89,000 a couple weeks ago and the lights went out. But...came back on Thursday and decided to take on the fix. It was pretty straight forward but getting those 3 hex heads out on the bottom with the unit still in place is a trick. Take your time. Use the shortest 4 mm hex head you can find, and know those bolts don't just break free and spin out with you fingers. You have to hold the unit up and turn the hex wrench around. Took it for a drive and no lights as yet. The write up in the stickies is a huge help.
Old Dec 12, 2010 | 09:24 PM
WindrockRover's Avatar
Congratulations! I've been dying to try this on my 01 as well, but just haven't gotten up the nerve to pull the trigger.
Old Dec 12, 2010 | 10:04 PM
SDinDS's Avatar
My only reason for not doing it yet is that the weather here in TN hasn't been very cooperative lately as you've probably noticed.
Eric
Old Dec 12, 2010 | 10:57 PM
I got out and enjoyed it a little tonight, although it would have been even more enjoyable with my ABS and TC...
Old Dec 13, 2010 | 08:54 AM
oysterhead's Avatar
Having a local guy do the fix for me as we speak, along with head gasket.
Dying to play in the snow with my Rover!
Old Dec 13, 2010 | 01:45 PM
Jeff5123's Avatar
How long did it take you to do it? I think I'm going to tackle it here pretty quick.
Old Dec 13, 2010 | 02:01 PM
ShortTom's Avatar
Excellent. I'm going to tackle mine this weekend even though the Amigos haven't visited for a couple weeks. I don't want them to come on in the middle of a snow storm.
Old Dec 13, 2010 | 02:43 PM
texmbr's Avatar
It took a little more than three hours but was interrupted several times by Miller..my buddy. I really think knowing what I know now it can be done in an hour or so. The limited space to work is the biggest issue. Find a 4 mm hex head that has the shortest leg possible for the 3 hex heads on the bottom.
Old Dec 13, 2010 | 03:06 PM
ShortTom's Avatar
So no brake bleeding afterward if you just take the front switch off right? That's how I interpreted the DIY anyway...
Old Dec 14, 2010 | 08:26 AM
texmbr's Avatar
Correct ShortTom. No need to bleed as you do not disconnect any brake lines with the Option B. Getting your hand under there and removing those 3 4mm hex heads is the hardest part. Oh and putting them back.
cipher982
Jul 3, 2013 06:03 PM
kenk
May 26, 2012 08:11 AM
coors
Nov 28, 2011 08:29 PM
Princess
Jul 4, 2009 12:24 PM
